ORD swaybar ends?
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
anyone have an issue with the bolts that secure the extended links to the spring plates backing out? I crawled under my kids blazer with 4" ORD front springs and the ORD swaybar kits, and the bolts were missing on both sides.
Ill get new hardware and loctite it, I just was surpirsed they both back out.
Bennyt
Surprise
Ben
Did you use lockwashers? If you did that could be the problem. If a lockwasher is under the bolt head, it doesn't allow the bolt to stretch correctly and the washer will often break and fall out and allow the bolt to loosen. I've seen that happen on swaybar endlinks and also the 8 bolts that bolt the axle to hub on 14bff
malditorama
