Opinions: Newer bed on older truck...
SlickGTP
Houston, TX
Thinking about swapping over to an '86 bed on my '73... It would sure as hell fix my rust issues and make it a bit easier to fill the tank. My only hesitation is that even though my bed has a bunch of pitting from the rust and I'd have to patch over the wheel wells, it's a solid and straight bed.
What do y'all think?
It's a direct swap. Differences being, you'll have gas tank fillers doors. I like those better than a gas cap hanging out of the side of the bed. If you get the 86 bed for a good price and it's in good shape, for sure, I'd be doing it. I see nothing to gain by keeping the OE 73 bed if it's rusted up pretty good and needs plenty of work.
^^this....on my '77 I did exactly what you're contemplating SlickGTP. My bed is actually off a mid 80's truck and it was 100% rust free with just a few minor dents to be fixed. It's a direct bolt on. So if it's in better shape than you have now then do it :waytogo:
SlickGTP
Houston, TX
Cool... I was thinking along those lines. Just needed a little affirmation on the thought process. The existing bed I have a feeling will need at least $150-200 worth of work. So, if I can pick this other one up at a good price I'll probably jump on it.
Thanks guys! :waytogo:
J Knight
Baytown TX
82 Chevy
350ci
I would swap no problem, just use the 73-80 tailgate. It would look way better imo.
Boondock
North Carolina
350 cu. in. (5.7L)
The newer beds also don't have the same flares as the older ones.. So it may look off a bit.
Stroked
Beloit, Kansas
Jared
Oh? Guess I've never noticed that. I'm actually planning on putting a 73-80 bed on my '84 for the time being until I can track down a good 81-87 bed.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I don't think it will work. I think the latches are different or something. I know FoamyPirate tried an older tailgate on his bed and it wouldn't fit.
Mine is a mid 80's bed and i have the 73-80 tailgate :shrug:
which flares are you referring to? :think:
Indeed :shrug:
I just wanted to shrug again :roflbow:
Stroked
Beloit, Kansas
Jared
I was thinking something was different between the two as well. :shrug:
But I will add that I'm sure I've seen an 81-87 tailgate on a 73-80 box...
J Knight
Baytown TX
82 Chevy
350ci
73-80 tailgates had 2 designs, 73-76 and 77-80. 77-80 will fit with no mods but you do need the larger 73-80 trunions installed on the 81-87 bed for a perfect fit.
X2?!?
2manysquares2care
