NP208 leaking from shift select arm/bracket
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Can the seal on the selector bracket be changed out, without having to remove the TC from the truck?
legopnuematic
Licensed Junk Dealer
MO
Spencer
You should be able to. Might be worthwhile to remove the front driveshaft to get a little better access. Remove the nut holding the lever on, remove lever, use a slim pick to remove the nylon outer washer/bushing and then the o ring. Clean area apply some petroleum jelly to the new O-ring and slide on, followed by the nylon bushing, install the rest of parts.
Also make sure the 4wd indicator switch isn’t leaking, or in my friends case, forgot to install the switch or a plug and wondered why it was leaking… It’s located such that if it’s leaking it will be inline with the shift shaft.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
legopnuematic, Thank you. I was praying there wasn't a seal inside the case.
legopnuematic
MO
Spencer
No problem, also while you are under there make sure the transfer case vent is not plugged up, a plugged vent won’t do you any favors trying to chase a leak down.
Monstah911
