Not enough Edelbrock 1406 fuel pressure ?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
As many will recall, I recently had a no start problem on my truck with no fuel getting into the carburetor.
New carb fixed the problem, truck has been doing fine, until a couple days ago.
Once again, same issue.
Checked everything and had plenty of gas gushing from the fuel line (electric pump running) when the fuel line is pulled from the inlet fitting.
Regulator set at 4 psi.
Friend tried the old trick of tapping on the carb with a screwdriver handle and VOILA, gas flowed and the truck started.
Is there a chance I need to bump up that setting to overcome the inlet needle/seat assemblies despite that much gas flow and pressure ?
Or should I return the 1406 under warranty due to floats sticking and get another one ??
Scott91370
Burleson, Tx
Scott
Sierra1500
I'd go up to 6psi. I think the range is 4-6.
hogdaddy
Alabama
mike
Scottsdale
I agree in bumping up the pressure. What filter, regulator and fuel pump?
Have you replaced the rubber lines in the rear from tank to hard lines.
Picture of fuel line going to carb?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I should replace those rubber lines, as it has been many years and lots of ethanol gas, and many of us have had experience with deteriorated rubber lines from that crap.
Plus, I have a bad habit of running multiple fuel filters and there's a chance each tank has a filter at or near the intake side of the selector switch as well as the inline filter just as the fuel enters the carburetor.
Will work on getting a pic if it warms up outside and I am able to hobble out to the truck.
So far I have been lucky the assisted living facility hasn't bitched about my old ugly oil leaking truck that only runs when it wants to.
hogdaddy
Alabama
mike
Scottsdale
Duel tank setup then? I am not familiar with those and never had one but yes those rubber lines and ethanol don't mix well.
The fuel injection hoses would be better I assume.
1STLS1
West Phoenix AZ
MIchael
As found in their tuning manual:
Fuel Pumps and Pressure: Avoid extremes in fuel pressure. At IDLE, there should not be any more than 6.0 psi; if the vehicle has an adjustable fuel-pressure regulator, set it to 5.5 psi. With most fuel pumps the minimum fuel pressure is encountered at high rpm and WOT. Fuel pressure should not drop below 2.0 psi. If it does, a fuel pump with more capacity may be required. Note that some later model vehicles (the 5.0L Ford is one example) have mechanical pumps that will give more than 6.0 psi at idle. The vehicle will perform well, but may be prone to stalls on quick turns and stops with the clutch disengaged. If this problem occurs, check the fuel pressure. If it is more than 6.0 psi at IDLE, it should be reduced through the use of a regulator, such as Edelbrock #8190, or by creating a restricted by-pass bleed to the fuel return line. Edelbrock Street Fuel Pumps are highly recommended for all Edelbrock Performer Series carburetor installations.
Always use a filter, such as Edelbrock #8873 between the pump and carburetor. Note that a good filter is large in area, so it may be able to transmit a significant amount of heat to the fuel. It is a good practice to keep the filter away from heat and not allow it to come in contact with any part of the engine.
Statewide001
