I noticed when it started to get cold that it would start drain back to tank(havent done pump yet, behaving as expected.) and because time and money are tight, i figured to toss one on because i already had them. It does seem to work. Id say still needs 2 pumps to start after sitting for a long time but thats not unreasonable in my opinion. starts right up. Could be my timing + carb settings, too, so there is that.
You could put the throttle bracket in the back the carb supports a pull from up(to snap throttle closed) or pull from back down(to snap throttle clsoed), I couldnt use my original bracket because it wanted to interfere with the springs(the cable)
