Lift3d1
- Jul 24, 2019
- California
- erik
- c1500
thanks guys, i will work through these suggestions.
i assumed the battery is ok as everything worked til it didn't. i didnt get any slow cranking or indication the battery was going bad. first thing i did was pull the battery water level plugs out and inspect and there was possible one low cell but not obviously low. i put my digital charger on it and it immediately read 55 and then charged to 95 no problem. today, since the last time i tried to crank it it clicked a little longer duration and it thought it sounded strange. it didnt sound like it was going to turn over or anything but the duration of the clicking sound was definetly drawn out longer. I put the charger back on it and it started at 75% but it hasnt been used siince yesterdays 95% charge. maybe its just a bad battery???? i hope thats not all it is after all this!!!!! i will take it in tomorrow for testing.
The battery posts are spotless. The batteries warranty is up end of this month. It is an ORileys battery that was bought last january. sticker on it reads 1/23.
I will find and clean the ground from engine block to body. If that dont solve it, i will buy/install the ignition switch.
Thanks again guys, i really do appreciate it. Im having to share a car which is no big deal but....
