brooksman9
- Sep 26, 2021
- Olive Branch, MS
- Patrick
- Silverado & Custom Deluxe
- 350 & 305
Nick,
Didn't want to highjack the other thread but hoped you might answer a couple of questions regarding TV cable setup and the pressure testing mentioned in the other thread. Back story is I bought this 86 K10 from a guy I was working with a few months ago. He only had it for awhile and decided to get rid of it. When he got it he said it had an intake leak. He replaced the stock GM intake and Q-Jet with an Edelbrock intake and an AVS Carb. I had to finish the install and get it all running. No big deal.
The more I read about TV cables I wasn't sure I had it set right. From what I had read to set you push the tab in, slide the sleeve back release tab and floor the accelerator cable. It did not ratchet out as I had read but stayed retracted. It did extend though if I held the button in and had someone floor the gas pedal. Pic is how it is set now. Also had to purchase the adaptor for the TV cable for the accelerator bracket. It does shift around 15-20 mph 1st to 2nd. Can't really tell about 3rd. It is either not moving fast enough or too soft for me to feel. I have only driven around the block a couple of times. I have been working on several other things with the steering so slowly getting around to this part.
1) Does the setting look about right? I know the distance difference from the Q-jet to the AVS is about 3/4" less.
2) Watched a few pressure testing videos on Youtube. Do you think a HF pressure gauge is good enough? About $30-40. Summit is around $60.
3) Attachment port driver side of transmission above linkage?
4) What is pressure at stall? In gear and giving gas to RPM of stall converter? Sounds kind of risky to me. lol
5) Thanks.
5) Thanks.
