Newer Style Center Caps & Wheels On 1978 3/4 Ton Pickup-Stud Question....
CORVAIRWILD
Uppa US
UGLYTRUK
K2500 Suburban 4x4
My friend has a 1978 Chevy 3/4 ton C20 pickup with newer 2000 or so chrome wheels. He's missing the center caps, but the question is, what stud and nut needs to be used? The truck has a couple of the double threaded nuts, but my review of ebay shows that they're all 14mm metric. So I'm really curious how the truck could have metric nuts on SAE studs? I only saw the truck for a few minutes, but I hope to go back and look at it, and maybe remove a stud to see exactly how a metric nut is installed on what should be an SAE stud.
I emailed a couple of ebay vendors to enquire about SAE double thread studs, and all they had was 14mm netric.
I'll also have to see if the rims are painted with chrome covers. I read about the chrome covers available for silver painted wheels, and my brief encounter with the truck I sort of noticed what may be a chrome dress up cover on the painted wheel.
BTW, the truck is in Israel, where I'm vacationing now.
CORVAIRWILD
Uppa US
UGLYTRUK
K2500 Suburban 4x4
Wow, that was fast!
yevgenievich
Place
Name
Year
Model
Size
Dual thread nuts are the ticket. I used the smaller version on my 85 couple of years back
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Holy moly! Thats awesome! I've been wanting to use newer-style lug covers on the dooley but haven't been able to figure out the lugnut issue. I guess this takes care of it! SWEET
Big Chip
Michigan
Kevin
C35
The dually lugnuts are a 90 degree cone as opposed to the 60 degree cone of the duplex lugs. I’m not sure if the rings can be remachined or of you can machine the lug nuts. I’m not even sure if it makes any difference but I assume it wouldn’t be good to mix and match cone angles.
Big Chip
Michigan
Kevin
C35
Huh, never noticed that.
Perhaps newer trucks with metric lugs used the 60 degree taper and those rings might fit?
RogerioHR
