New stater not catching
TheBigBlue2500
Bellefontaine
Nathanael
Just switched out my old starter and my new will not catch. I've had this issue before with my last square, a 81 k10 with the aftermarket starters not catching the flywheel. I did install the braket and it's on nice and snug however it will not catch. Should I go get a different starter or is a there a "proper" fix?
75gmck25
Northern Virginia
Bruce
Did you measure the clearance between starter gear and the flywheel, and use shims to adjust it?
Doug Hampton
