Speaking from years of experience as a suspension specialist. Arching an old spring does not last without adding a leaf. Actually the arch is not the benefit but the addition of the extra spring rate from the added leaf. The ride doesn't change much when you add a leaf because the old spring is weak and you are getting closer to the original strength. If you are going to pull a trailer there is no replacement for new springs. Insist on Dayton or Flagg springs ONLY!!!
I recommend a sway bar if you're going to hall much weight or tow a camper. Overloads are okay if there ones with the brackets that are on the frame and adjusted properly.
I love air bags and there adjustability but I still recommend a sway bar.
I new here, recently purchase [September 2014] an older 1986 K30, M1031 CUCV, first pickup truck I have owned.
Read/reviewed this posting, as I have a leaf spring issue.
One of the leafs on the rear springs, the driver side is cracked {leaf number 3].
Think I will be replacing both sets of leaf spring with new one. The current spring are the original standard that where installed on these trucks, 9 leaf pack and one auxiliary /helper spring.
My intention is to use this truck as a daily work / service truck, as they where originally designed {truck has the original PTO generator, air compressor and welding machine]
If you where to "upgrade" the rear springs, replacing them with a new set what would you add?
Searching before I located this forum I was looking at new replacement spring manufactured by Eaton. Will be looking at and comparing spring's by "Dayton" or "Flagg"* as recommended by poster/user "chevyk10".
*FWIW, Flagg are sold under the trade name Triangle Spring
Your Comment, Suggestion and or Opinions.
Thank You
Joseph
