luna negra
- Jul 3, 2019
- central texas
- luna
- Jimmy
I've got a rusty '79 K5 with some rocker and floor pan issues. I've never tried to do body work so before I start cutting and welding, thought I would ask here first. My main question is how much to take off and replace. The driver's side rocker is not that bad except for one part. Would you just try to replace this bad section or go much larger? Also, what's confusing me is the order of things - I assume I start by cutting the outer rocker off, then fitting that back before the inner? Or do I fit the inner and outer together, then tack? The youtube videos I've seen aren't clear on the order of things. I presume that the outer/inner has to be done before anything with the floor pan correct?
Passenger side
To confuse things further, the aftermarket inner rocker piece that was sent by RockAuto doesn't really make sense how it fits - it's much too short for the overall outer rocker length. Any insight y'all could provide would be greatly appreciated. Thanks!
Passenger side
