RyanTexas
- Jan 6, 2012
- Corsicana, Texas
- Ryan
- K20
Hey guys, I am a new member on here and just recently traded for an 86 K20 Chevy with about 15 inches of lift or so, sittin up on 44 inch Boggers. It didn't steer for **** when I got it and would actually try to dive for one ditch or the other at very low speeds, so I swapped in another steering gear which did not correct the problem. The lift on the truck consists of a 3 inch body and the rest is all leafs. No ******** blocks. But as for the steering components, everything is stock except for a home made drop between the tie rod that connects to the pitman arm, which is stock, and the tie rod connecting at the driver's wheel. I understand that I need a drop pitman arm, but the biggest drop I have seen is a 4 inch. Is there a company out there that makes a drop between the tie rods??? I like how genius the redneck that originally built this truck was with his drop tie rod invention, but they are welded into a 1/4 inch plate that drops them about 5 inches but are non serviceable. They have slack in them and I can't change them. Now there are probably 20 Chevy's on 44s in my county alone, but I want your input so I can buy the right **** the first time. I'm going to change diff fluid out sometime this week and figure what gearing the truck has, which I am afraid is stock. The 454 and 4 speed combo are in good working order. Pics on my profile. Thanks guys
