Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
As a preface, forgive me people if my spelling is ******, im having difficulty seeing right now. I think i need reading glasses.
so i had that annoying axle whine return a little after i installed my posi a couple weeks ago. Very shortly actually.
Today i pulled apart the axle again, since i probably need ti change the fluid from any grease or initial clutch dust from the yukon.
Inspected my carrier and pinion bearings. All good. Nice healthly wear patttern in bearings. No bad parts, but i warrantied them anyways thru parts store. national brand.
Gears looked ok too. Installed new pinion bearings anyways.
I previously torqued them until i got 19 in/lbs of preload. The appropriate preload range is 14-19 in/lbs.
Today, i torqued with with new crush sleeve to like, 14 in/lbs thinking maybe the bearings i had just couldnt take that much tension (19 ib/lbs)
Still whines when i decelerate.
I know everyone may not have worlds of knowledge on this, and neither do i, but im open to suggestions, maybe im overlooking something.
Heres the facts:
When i setup those rear gears 3 or so months ago, i rode on them for like 1.5-2 months. Not a whine, squeak, or whirl. That was with new carrier bearings, and new pinion bearings, and new gears. All was right in the world, until the truck fell off of the lift, and ive been chasing this noise since then. Im really ******* scratching my head on this one. And need a suggestion.
Im out of ideas. No matter what ive done, the whine WILL NOT go away. I had a thought today just a moment ago, which prompted me to message. What if when it fell down, it bent an axle shaft, and that bent axle shaft(s) has wiped out the wheel bearings ?
Some clues hat makes me think bearings:
On a cold startup, heading down the road, i wont hear a noise anywhere until about 10-15 min into driving, and the sound jusy increasingly gets worse and worse. Its like a thermal issue. Something heats up then begins its BS
the facts
• Its not a continuous whine, at any speed, taking off or slowing down, or cruising, like a bad gear setup.
• It doesnt whine when accelerating, like carrier bearings.
• It only whines when i decelerate, and very occasionally at cruising speeds for a moment, then goes away.
The sound description:
Occasionally cruising i will hear a random "eeeeeeeeeeeeeeeeeee" that sounds like its resonating thru a tunnel, but goes away shortly after.
When slowing down, coming to a stop it makes a "woo woo woo woo woo wooooo" sound (lol)
technical details of my current axle setup to eleminate any sort of confusion
new crush sleeve as of today, torqued at 300 ft lbs,
Pinion preload, as i said, 14 in/lbs
Carrier bearings 2 weeks old, caps tightened to 60 ft/lbs
Backlash was set at 7 today.
Pinion bearings and races replaced again, today, despite me having no reason to suspect them being bad, all were greases prior to install.
Yukon posi in axle, noise was present prior to install. Additive added. 80w-90 gear lube.
Richmond gears in axle. 4.10 r/p
I did do proper annealing cycle, per spec. (300 miles, stop, cool down, 300 miles, stop, cool down, etc etc. )
Again, i had no issue whatsoever when i did gear install 3 months ago. No whine, no noise, nothing, until truck fell off of lift, and tires contacted concrete truck during fall, with truck in park.
Hit me with WHATEVER you got im all ears.
I may be an idiot, but given my resume of ability, and background in this and other things, i find it highly unlikely it was my job with the gears.
I personally think it is something else.
Read over all the details, and lemme know what you gents think.
Heres the facts:
the facts
