OldBlueDually
- Jun 8, 2020
- Minnesota
- Justin
- 1976 GMC
- C30
- 455 Olds
I HATE admitting this, but I got a good deal from my father in law on a 2007 ford taurus with the 3.0 V6. So I thought it was a good deal, car was rust free, driven by his dad, low mileage, from californy. (Shoulda kept my 320,000 mile 2002 Impala 3800--it was lightyears ahead of this POS taurus). I have had AC lines blow out on this, wiring issues, blew the transmission out--and I drive this thing very nice! Anyhow.....
However, the last couple weeks sometimes it starts fine. Sometimes it cranks slow and starts. Sometimes it just "clicks" when you hear the solenoid engage the starter. When the engine is hot, it won't start, you just hear the click of the solenoid.
Here is what I have done: I did a load test on the battery, turned out good. I swapped around starter relays, still no change. I disconnected the battery and all grounds, cleaned them up & tightened back down, still no good. Cleaned the positive to starter, verified solenoid wire was clean/snug. Still no good.
So, I had my wife sit in the car with the key in the "start" position, I used a long 3/4 drive ratchet and nailed the starter with the handle, it engaged-cranked slow and started the engine. So I thought to myself ok this is the starter causing the problem, I will get a new one.
The following day I go to Orielly's in town here & pick up a reman starter and install it. Guess what happened when I went to crank it over? Yup--Click, click, click...then it cranked over (fast) and started.
My next test was going to be: Use jumper cables from my Suburban to this taurus and see if the car starts or not--Maybe this would indicate a bad battery even though it load tested fine???
Do any of you have experience with something like this & could lead me in the right direction? I hate this effing car.
