Daveo91Burb
- Jul 6, 2014
- Vancouver, WA
- Dave
- V2500 Silverado Suburban
- Vortec 383, modified TBI/4L80e
HyperTech makes something for TBI called the Power Charger. Basically eliminates the "choke ring" that goes around the injectors and provides a support for the air cleaner (and also creates a lot of restriction). Got the idea for a home made one on another site - here's what I did.
Bought set of four metal mixing bowls for $11.99 at a discount home goods store called Tuesday Morning. I got the second biggest one and my wife got the other three. The one I used nested perfectly under one of the ring insets of the OEM air cleaner's base. And I cut out the overhang of the base so the transition is smooth and I have the biggest opening possible into the mixing bowl. drilled a hole for the PCV breather tube in the mixing bowl. (Could also use a breather in the valve cover) And I cut the bottom flange off the choke ring, leaving about 1/8" to 1/4" of the ring, and then installed that into the base of the mixing bowl, in the hole that I had cut out. Gave the bowl something to rest on at the TB and also gave it rigidity, it was pretty flimsy with its bottom cut out
