cah2873
- Jun 27, 2016
- East Texas
- Chance
- K20
My passenger side Manual Window Is Hard to Roll Up. I have had the panel on and off the door around 15 times adjusting and trying to make it work correctly. 1st of the all, when the window would go up about 3" above the trim seal, then the leading edge would work its way out and the window would come out of the track. I check the vent window track and door to make sure they are not bent.
I have also installed a new regulator trying to help remedy the problem along with a new seal back earlier in the year. I corrected the problem of keeping the leading front edge of the glass in the track by installing a carburetor spring from the back of the bracket on the back seal to the side of the door underneath the regulator track. This seems to put just enough pressure to not allow the float out of the track. Is there a special lubricant that can be used to help and spray in the track? I am out of ideas at this point.
