I'll throw my hat in the ring here. Lots of variables go into play when picking the right cam. For your application with the increase in cubic inches, the lack of a torque converter due to the manual trans and no vacuum brakes would dictate that you could get away with a cam a couple sizes larger than what the "book" calls for. However, it sounds like you want to build a torque monster. But out of the cams you have listed above, I'd put my money on the 20110121 based off of your desire and the cubic inches you are building to. "Off the shelf" Camshafts are designed to fall within a certain cubic inch "range". That's why you always hear people say for example "I had great luck and made tons of power with this *** cam in my 355 so I reused it when I rebuilt and stroked the engine to a 383 and now the power just doesn't feel like it's there anymore". Because larger cubic inch engines require more demand from the increased displacement. Think of it like a giant air pump, which coincidentally is exactly what it is, if you increase the volume of the pump, you also increase the demand of the pump, so you need to feed it more for any marked improvement. So you need an Increase in lift and duration and you can play with lsa and centerlines and cam timing until you're blue in the face. so to fully benefit from it is a question truly left for the experts. That's why stroker applications can really get a little tricky with camshaft selection. Grinding a cam on a couple degree different lsa can make a ton of difference in the drivability and power down low. Just as much as degreeing a cam or altering the timing of it (timing of the cam, not the ignition) can make or lose 25+ hp in certain applications. And then, are you going to do anything crazy with the heads? Larger valves, opening up the throats, porting, port matching, unshrouding? What intake? are you going to run stock ratio or increased ratio rockers? etc etc? Some people don't realize it, but Velocity is key to making good power. And then you want to throw fuel injection on top of it, so that is going to have to be figured into the mix as well. So at the end of the day, if you really want to get the most bang for your buck, do as stated above and call Lunati and have every shred of information on your build and vehicle available that you can, and they'll get you a cam that falls right in your wheel house. You won't be disappointed.
