I don't think that there's a single person here who will tell me that a modification for better safety, is a foolish one. (If they do, check their BAC for me.)
Replacing starndard incandescent bulbs with LEDs has been going on for quite some time. The change over makes perfect sense. LEDs are superior in every way to standard bulbs.
Up until a few months ago though, you would have had to figure out how to engineer your own LED board/assembly and controller. LMC has teamed up with Technostalgia to bring us an all in one package, and at only $100 for the set, this is a cheap mod that anyone can do in their driveway in an hour...
Starting things off, we have here some basic tools that will be used.
Wire cutters/crimp tool
Dikes
Phillips head screw driver
Torx set and Socket wrench
Heat gun and heat shrink (Not so common, but for $25, get a heat gun...)
Here we have an LED assembly, new tail light lens with "chrome" trim, and a few crimps to make the job easy. (You can solder the connections that will be made, but I have a personal preference for crimps in this instance)
Start by removing the 4 torx head screws that hold in the tail light lens. All are pictured here.
Now remove the 4 Phillips head screws holding in the tail light housing. Remove the bulbs from their sockets and then remove the socets by twisting them and pulling them out the back of the housing.
The socket we need is for the tail lights (duh?). Make a note of which wires were where just in case something gets screwed up... There are three wires going to the socket: brown, black, and yellow (driver's side) or green (passenger's side)
Moving onto the LED assembly itself, you need to remove the gromet from the stud that it is mounted to. There are two nuts at the top of the stud which must be removed.
Now pull the wires back through the gromet and pass them and the stud through the hole where the tail light socket was originally located.
Dikes
