tadslc
- Jan 20, 2020
- Birmingham, AL
- Tad
- C10
- 350 Blueprint
I recently purchased a LMC EFI Tank kit, #32-5984.
Install went well until it came to the fuel gauge reading.
When I fill up its only showing 1/4 tank and this goes to 0 quickly.
Checked gauge and it works as it should. Disconnected pink wire from sender, needle goes to 3 o'clock position, ground pink wire it goes to 0.
Purchased a new sender from LMC. Checked ohms, correct. Hooked the sender to the pink wire and ground outside the tank and the gauge works as it should. FYI - These come with the "floatless" style sender.
Dropped the tank, installed the replacement sender, reinstalled everything. Nothing...
Does the exact same thing as the other sender.
What am I missing???
Thanks!
Thanks!
