Lights and wires
tsn98
Connecticut
Tom
So last night I was finishing buttoning up some stuff on the interior of my 88 K5 Blazer, I just installed an aftermarket radio and speakers as well as some custom interior panels, and I turned on my lights, and my dash lights didn't come on, and my headlights are being funky, all 4 are always on (it's got an 89 grille and light setup on it) but they're on super dim, and on the driver's side when you switch from low to hi beams, the both stay on but whichever one is selected gets bright, but both are always on. The passenger side, both just stay dimly lit no matter is hi or lo beams are selected. I checked the fuses and they're all good... tried everything I could think of... Also when putting in the radio I found an orange and a brown wire that come up behind the radio, the orange having constant power and the brown having power only when the lights are turned on. Not sure if they're related to the dash/headlights problem or something else entirely. Anyone have any ideas?
Sent from my Pixel 2 using Tapatalk
I'm fairly certain that (without some modifications) the H/L design of the wiring used in your 88 isn't compatible with the V22 RPO option (quad headlights) installed in the 89 grille/HL setup. Prior to 1989 the V22 option had one dual filament sealed beam and one single filament sealed beam. This was how they looked:
And this is the wiring diagram for the 88 and down circuit - note the three pin connectors used for the HI/LO headlights:
Here is the wiring for the 89 and up V22 option - both sealed beams were wired with a two pin connector:
So, the later models did not have the two headlights on at the same time.
As for the radio wiring: is it possible that the colors are not orange & brown but rather yellow & gray?
If that is the case, the yellow is ignition switched power and the gray is spliced into the instrument lighting circuit and is backlighting (you don't need it with modern head units)
tsn98
Connecticut
Tom
Thanks for all the info! There has definitely been significant modifications to the wiring and a whole new radiator support etc put in to convert the headlights by the previous owner. He appeared to leave ALL the wiring for the old headlights still attached and spliced the new ones in so the wiring up in front is an absolute mess.
There is definitely an orange and brown wire coming up behind the dash that has a connector on it but isn't connected anything, but there is the yellow and gray like you said that go into the radio, I removed the grey illumination wire like you said and bam! The headlights are back to normal! Dash lights still aren't on... But it's progress for sure.
Checked the fuse for the dash lights and that's still good... Any ideas on those or on the two mystery wires???
Thanks for the help!
winfred
