Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
Hey Everyone,
After some time of enjoying the leak free truck it appears to have sprung a new oil leak.
I am seeing large dark drips (darker then my engine oil) off my lower radiator hose which appear to be coming down the back (end from the water pump). I am also seeing the same large, dark drips from the bottom of my fuel lines right off the fuel pump.
And also a coolant leak somewhere, only place I am seeing coolant is on the transmission lines at the back of the engine oil pan. Since I'm not seeing the normal thermostat housing leak or anything else I'm thinking its time for a new water pump.
Any ideas on this Engine oil leak though? My intake and valve cover gaskets are newer and not showing signs of leaking, I'm not loosing a lot of oil or having oil and coolant mix so I do not think its the head gaskets. Rear main, Oil Pan and Oil Pan gasket also are new and no signs of leaking.
So where to start? timing chain cover and gaskets? or is there a gasket at the fuel pump or fuel pump plate that should be replaced??
