youcancallmedusty
- Nov 28, 2022
- Colorado
- Merrick
- v2500
Hi, this is my first post but I have been using this forum for information for a while now. I have a 1987 gmc v2500 5.7l. My issue is that my coolant turned from the normal slightly dirty/rusty to black with a touch of green from the Prestone within a couple of days. I noticed I had lost oil pressures week and a half ago, usually idle would be 28-30 and now it is closer to 20 and it bumps up to 28-30 when accelerating. There is no coolant in the oil and coolant doesn’t look oily/milky or sludgy, it just is black. A couple days ago it was pretty normal colored, not especially clean but not as dark as it is now. I recently replaced my radiator and did a flush when doing that so I do not believe it’s from rust or hoses. The upper rear passenger side of the engine has developed a oil leak, it seemed like it was seeping since I would only find oil on the front driveshaft, valve cover,starter and head on the passenger side. When I changed out the spark plugs last week I remember seeing that cylinders 6 and 8 definitely were fouled with oil and oil on their threads. Front driver side of intake manifold has a seeping coolant leak. Other than the black colored coolant, slightly oiled spark plugs, and seeping oil leak there are no other symptoms. Maybe some loss of power accelerating up hills but to be honest the stock 350tbi was never a speed demon with the service body on the back being full of tools. There has been no black, blue, white smoke, other than briefly in start up due to the valves not having seals on them. The truck has not overheated and stays within spec of the thermostat, it runs fine other than less power uphills but honesty that could just be me overthinking it and driving my girlfriends Subaru occasionally and getting used to the peppyness of it. Before I start tearing everything down I was hoping to get some opinions, I did read that it might make sense to try to retorque all the head bolts down in case they had gotten loose,l. If anyone has any other ideas of what could be causing the black coolant and loss of oil pressure I would love to hear it, if it is the head gasket then I would like to get going on it since it seems time consuming to replace and would be my first time doing such a project. I can post some pictures of the coolant color, seeping oil leak and whatever else is need to help me get steered in the right direction of figuring out the issue. Picture is of the truck
