Skyler MacArt
- Sep 29, 2019
- Utah
- Skyler
- K20
So my stock engine in my truck is pretty much done for. Its burning a lot of oil out of the passenger side bank. I also have a 1985 c4 corvette with the l98 engine. I'm in the process of ls swapping the vette and want to put the l98 engine in my truck. I want to keep my full serpentine belt system. I will pull the tip intake and swap to a carbed intake and I'll pull the electronic controlled distributor and add the vacuum adjusted truck one. My main question is aside from adding a fuel pump and regulator what else should I need for the swap. The engine already has the smog pump eliminated my main concern is my radiator fan. I believe the corvette water pump is reverse rotation. I dont really want to spend the money on an electric fan kit. Is there anyway to put the truck mechanical fan or entire pump on the vette or is it possible to remove all the brackets and switch to a v belt pulley system on the l98 or do I absolutely have to buy electric fans. I'd prefer the serpentine belt with a mechanical fan. Any other info on the swap would be greatly appreciated aswell.
