mtnmankev
- Jun 10, 2014
- Ash Fork, Arizona
- Kevin
- K10, C20
- 383 Stroker, 350
Chev 350 86 vintage one piece rear main seal block.
After running the fresh engine off and on for about 20 to 30 minutes at 1500 to 2000 rpm to break in the cam and lifters, the engine started a new issue.
After it sits a while and we restart it, there is a knock that sounds just like a worn out rod from an engine with a million miles on it.
The sound goes away in about a second as the oil pressure builds.
The original crank was out of round on one throw, so the machine shop ordered one in.
It came with correct bearings, and plastigage is showing .001 to .0015 clearance on the first two throws, will check the other two after I eat some food so I don't collapse working in the heat.
I see some microscopic "scratches" on the bearings, but no deep grooves or scores.
Everything in the engine had liberal amounts of assembly lube so nothing was run dry.
I am not sure if mains can cause that noise if they have too much clearance, but I will check them also.
If the rods were not reconditioned properly at the shop, could that cause them to make the knock and not show up on the bearings as wear?
I am at my wit's end, and out of ideas what to look for now.
