I agree. I have rebuilt and tuned many Edelbrock carbs (the ones loosely based on the Carter AFB). Even bought and sold them on eBay for awhile. They are great for guys who don't want to mess with carbs beyond setting idle mixture and speed. However, even the most basic Holley carbs can be fined tuned for perfect transition from idle to moderate throttle to wide open throttle using various pump nozzles. pump cams, and power valves.
About new Edelbrock carbs working right out of the box: I've found they tend to stumble just a little right off idle, and can benefit from more initial spark advance. Also, every last one of them that I've worked with has had heat soak (hot start) problems, which I think is caused by 10% ethanol fuel boiling out of the float bowls. The float bowls essential sit right on the hot intake manifold, unlike Holley float bowls which are surrounded by air. Back in the heyday of the AFB, and even when Edelbrock started making the carbs (in the 80s?), there was no ethanol in gasoline, so I doubt there was a heat soak problem. By the way, a phenolic or wood spacer will help the problem a little, but not solve it 100%.
Just found this article about Edelbrock heat soak. Some good ways to at least partially cure the problem.
http://www.edelblog.com/tech-tips/resolving-heat-soak
Finally, kudos to Edelbrock for having a very nice owners manual. I have used their calibration charts with great success when living at altitudes from 600 ft to 9000 ft.
https://www.edelbrock.com/pub/media/wysiwyg/documents/carb-owners-manual.pdf
