Don-T
- Jul 28, 2022
- Vermont
- Don
- K10
I recently bought a '73 K10 that needs a lot of work. The truck came with a 6" lift on it. I have removed the lift and replaced it with springs that are closer to stock. I am now trying to get the steering sorted out. I have removed the steering arm for the lift and bought a stock steering arm from an Ebay seller. Now that I have set the stock arm in place I am not so sure it is the corrent arm. It doesn't seem to me that the tie rod end of the arm should be as close to the axle housing as it is giong to be. Take a look at the pictures and let me know if the arm looks correct, or do I have the wrong one. I would like to install the correct arm on not have to take it back off. If it is not the right arm, maybe someone can post a picture of the right one. Thanks for the help.
