JACK34
Banned
- Mar 18, 2023
- OTR TRUCKER
- JACK
- C10
Just curious of all the hype. Is crossover steering worth it?
It's a 6 inch lift with 35s on it. It's pretty loose on the road. I spoke with Offroad Design and my local mechanic that has done this and they both said it would make a huge difference. With the Red Head steering box, Borgeson steering shaft upgrade, Reid Knuckle and new ball joints on the drivers side as well. Tie rod is new so it would pretty much be a new front suspension. New rotors bearings and races and brake pads. Offroad Design also recommended the steering brace they sell that goes from the frame to the cross member as well as welding in the frame plate where the steering box bolts on. Little pricey I know. Just wanted to see what you guys thought about it. Thanks so much.Depends on your uses and goals. For a mostly steet driver with 6" lift or less, probably not. Unless you already have a D60 (for ease of mounting a right side steering arm) and need to replace the steering box anyway. Then it's a worthy upgrade even if not "needed".
Copy. Great advice much appreciated.If the front end is loose and could stand a rebuild anyway, then you are still half that cost or more, fixing it up with stock parts. If you think you will benefit from crossover, then now is definitely the time to do it.
The "huge difference" depends on what you are starting with though, and where you drive. If you are driving around with loose joints and a poor alignment, then yeah it will definitely be a huge difference.
Even if you don't happen to go with crossover steering, the steering box brace and weld-in frame plate is still a very good idea.
Copy. Will do thank you!!Replace the rag joint as well. Stock replacement or a u joint shaft conversion.
