Intake manifold to head port mismatch
WFarm
Central Virginia
K5 Blazer
I pulled the valve covers on the 454 and recorded the casting numbers on the heads. As I posted elsewhere recently, the engine is a 1971 LS5 365 hp originally in a Chevelle.
The vintage Weiand intake manifold (PN WCPSQ) is for the large, rectangular port heads. My heads are oval port (casting # 3993820, 1971 365 hp LS-5, Open Chamber, 113cc Oval Port heads).
The engine runs great; no known issues. Is this port mismatch to be concerned about?
fast 99
Spokane, Washington
If it runs fine don't fix it. However, larger intake to smaller head port will be detrimental to performance. Square edge on head will upset air flow.
WFarm
Central Virginia
K5 Blazer
Exactly! If it ain’t broke don’t fix it, lol. But I was wondering if there was any long term detrimental effects. A reduction in performance is something I can live with.
fast 99
Spokane, Washington
I wouldn't think so. However, it would have more power [torque] with the correct intake.
Catbox
Peter
C20 Silverado Camper Special
Not an issue.
Run it all day long.
The air in the runner will flow where it wants to be.
Could it be better, sure.
Will you notice the difference if you change just that one part, maybe but most likely not.
Jugulator
