@Isaac nickerson,
It's obviously been leaking for some time. Also to, isn't it right over the heat crossover so it's real hot right there. Any oil coming past the bolt head would spread all over that immediate area. And look, take that stupid choke spring thing off and throw it away! You're obviously not using it. And isn't the EGR valve right behind that? I don't see it in the pics. Summit and others makes a block off plate and good thick gasket for it. But since you probably need it for proper carb function and timing and whatever the heck else it works along with, I can't recall, so you probably need to keep it.
If you change out to a high performance intake/carb. setup then you can chunk it. I wasn't paying close enough attention and bought the Edlebrock manifold that had the EGR port in it. Had I been looking I would have got the manifold that didn't have any of those ports. I had to get the block off plate and all. Edlebrock even makes one that has a port for that little spring choke thing, and the EGR. Silly.
Yeah, pull the bolt like the others have suggested and seal it. You're probably not leaking anything else from there but a tiny bit of oil. I know, it's worrisome. You don't want it to get any worse. But it looks like that's about all it's doing so it probably won't get any worse than what it's doing now.
