DutchSuburban79
- Jul 28, 2024
- The Netherlands
- Yoeri
- C20 Suburban
- 350cui
Hello,
This is my first thread on this forum.
So my windshield wasn't water proof that has been fixed. But after awhile the indicators/hazards weren't working.
I bought new relays, put those in and they still didn't work. Drove the car around without and now that it's been warmer I put the relays back in and the hazards work! All the bulbs flash, but when the lights are turned on the fronts flash seperate from the side markers. But the indicators do not. We put a meter to the purple wire on the steeringcolomm with the ignition ON. We got some reading when switching left or right. So I believe the turn signal switch is good. I remembered we tested the flasher unit a while back and it also clicked like it should. I checked the grounds up on the core support cleaned them up. Also when the brakes are pushed both brake lights go ON, except when the turn signal lever is pulled to either side, either side of the brake lights go out. So right on the lever (I believe) left bulb goes out, etc.
Can anyone point me in the right direction on where to look? I know the wiring in the back is a little dodgy so I will check that. But maybe someone here has the golden ticket!
Thank you in advance!
