Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
My son and I have been finishing up some of the winter upgrades to his 92 Yukon. Some of the upgrades include:
Rebuilt transmission
Rebuilt differentials with 4.56 gears
4 inch lift kit to go with the 36 inch tires.
New dashboard to replace the crumbing original.
Heated rear glass, heated mirrors
New carpet with lots of sound deadener
And rebuilt suspension, which is the source of my frustration.
The last few Suspension rebuilds I have been involved with I used energy suspension polyurethane bushings. I got the new bushings, I was surprised to find the instructions say to reuse the original outer shells and inner sleeves. All of my inner sleeves are either too rusty to reuse, or too damaged from wear. I called Energy Suspension, they told me they stopped including those parts in an attempt to meet a certain price break. To me, it seems stupid to expect a customer to reuse a wear item for a replacement part. That’s kinda like buying a crankshaft kit, and being told to reuse the bearings. I have no clue how much more the sleeves/washers would add to the cost, but more than likely I would have just spent the money to have everything I needed.
After exhausting all my spare parts looking for useful sleeves, I finally decided to just buy cheap stock replacement bushings to get the sleeves and washers. Only then did I find the aftermarket replacement parts have different diameter inner sleeves!!
My next move: I’m going to my local savalge yard to see if some of the later model wrecked trucks have useable parts. The salvage yard will give me the parts as long as the were damaged and not useable from collision damage. If I strike out there, I’m not sure what to do next.
It just pisses me off that the penny pinching todays manufacturing does has left me with a problem that can’t be solved. They expect you to reuse a consumable wear item, nobody offers the parts, aftermarket replacement aren’t compatible, and it seems nobody cares. Why would they? I have already made the purchase, they have my money, and won’t refund it because the parts have been installed.
Added insult to injury: I found out Dorman offers new control arms that are about 75 bucks more than what I have spent on ball joints and useless bushings. If I can’t find parts, that’s probably what I’m going to have to do.
