Hydro boost brakes awful sound after finishing motor swap
Ryanbrown36
Ontario, Canada
Ryan
c1500
I have just completed a Oldsmobile diesel to sbc 355 swap and on my first start every sounded great but the first time I pushed my brakes in it make a grinding noise, and would go away when I let off, I’ve had the truck running about 10 times since then and would come on randomly at idle, now comes on about 5 seconds after the truck starts, the brakes and power steering still work and the fluid is full, anyone have any ideas?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Have you tried bleeding it at all? Just finished as in never driven or really ran? Sounds like air in the system. I'm not fluent in the hyrdoboosts though.
legopnuematic
Licensed Junk Dealer
MO
Spencer
My hydro boost experience begins and ends with my Dodge, but I believe the systems are reasonably similar. They both use Saginaw pumps and steering gear, the hydro boost units themselves might even interchange (to some extent).
Anyways, mine took quite a bit to get it bled out, lots of turning the wheel lock to lock (in the air), pumping the brake pedal while running. Checking and adding fluid as needed.
Ryanbrown36
Ontario, Canada
Ryan
c1500
I haven’t tried yet, the truck was running with the diesel and everything worked properly until I did the swap so air would definitely make sense, I’m going to bleed it and see what happens, I just didn’t think air would produce that much noise but starting to seem like that’s what it is
Ryanbrown36
Ontario, Canada
Ryan
c1500
Thank you, will try this tomorrow when I’m off school
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
A "dry" fluid pump will make very many noises. Pretty loud usually too. Haven't you heard all of the 90's-2000's fords whining everywhere they go? lolol
jwconnelly
San Antonio
C15
I am troubleshooting mine for the same thing. Replaced the hydrbooster, all lines, power steering pump, and master cylinder. Spent hours upon hours bleeding and still does the same thing.
Ryanbrown36
Ontario, Canada
Ryan
c1500
I didn't get around to doing a proper bleed tonight but while messing with the carb and had it running for a while I took the cap off for about a minute and forgot about it totally, but now thinking back the sound went away. not sure how long it took to go away but it’s not there currently.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Is yours almost a grinding noise or a whistle?
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
I installed a hydroboost on my 1973 K5 Blazer while doing a LS swap. First I jacked up the front end and with the motor running, went lock to lock about 10 times.That purged a majority of the air.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Oh ok, mine only ever had one line off so wasn’t much air. Mine was almost a grinding noise but slowly went to a whistle and now nothing. But I assume I didn’t have much air in the system which is probably why it was so easy to bleed
jwconnelly
San Antonio
C15
Mine is a loud squealing when steering hits the stops. Same when you push hard on the brakes.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
jackh
