Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I preparation to reinstall my fuel pressure gauge, first I have to make up one end of this 1/4" steel braided hose. Use the side cutters to slightly trim any wires that are sticking out and may look like they would get in the way of the nut being pushed on the end of the hose.
Don't go up onto these threads because those threads are where the outer fitting goes inside the nut. It threads into the nut just like a screw.
But unfortunately I was not able to finish putting this fitting together. So I'll have to take it over the a hydraulics shop where I bought the hose and see what the problem is and maybe have them finish putting it together. Sorry. I know how to make up braided hoses I was an aircraft mechanic for over seven years and made dozens of hoses including all the hoses on my truck. They'll get it together tomorrow. Some kind of glitch.
Work the nut onto the hose end after trimming the little wires off the edge that might be keeping it from going on. Start out by beginning working it on by tilting the hole onto to the end of the hose and work it around until it's on the end of the hose all around. Once it's started you can use a tiny bit of motor oil inside the nut to give it some lube. Go to the first pic in the row below, because it's the one showing trimming the edge wires. Then the text for the above pic is the rest of the text that follows.
Once it's well started you can use a socket to be able to turn the nut while you push it on further.
This isn't to good of a pic, but what I'm trying to show is the end of the hose pushed all the way in by turning it and pushing it until it reaches the threads that are near the end of the nut.Don't go up onto these threads because those threads are where the outer fitting goes inside the nut. It threads into the nut just like a screw.
Then push the barb end into the end of the hose inside the nut until it reaches the threaded end of the fitting. Then while pushing the fitting end into the nut, turn it until you see it is started threading into the nut. Then you can put a wrench on the fitting and finish screwing it into the nut until it stops turning. Do not tighten it much more after it stops or it could damage the fitting threads. Now you are done. But unfortunately I was not able to finish putting this fitting together. So I'll have to take it over the a hydraulics shop where I bought the hose and see what the problem is and maybe have them finish putting it together. Sorry. I know how to make up braided hoses I was an aircraft mechanic for over seven years and made dozens of hoses including all the hoses on my truck. They'll get it together tomorrow. Some kind of glitch.
