Horn not working
Troyesco
Bay Area ca
Troy
Ok so I just picked up this truck and it doesn’t have the correct stock steering wheel. So I go to check horn and pull off the cover and see there’s no wire on steering wheel cap. I used my screwdriver to make contact and the horn sounded off once and no more??? I can hear the horn relay click whenever I make contact but no horn. The truck has all new wire harness from engine side firewall out and new horns as well. Could it possibly be the relay it does look original?
MisterB
Northwest
AJ
GMC K2500 4X4
It's probably not the relay or the horns. Most likely something isn't right with the horn button parts. I'd recommend getting the correct steering wheel and all the horn button parts on eBay/junk yard
Sent from my SM-N975U1 using Tapatalk
Troyesco
Bay Area ca
Troy
Ok also the turn signal lights don’t work with the switch but the hazard light flash with the hazard light switch
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
That sounds like the turn signal cam is causing the issue then.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I agree. Something’s wonky with the canceling cam, but I’d review what you have for contact parts and see what a horn contact kit is supposed to look like just to be safe. I wouldn’t run a non-GM steering wheel personally, but that’s not for everyone. Also, it’s pretty easy to directly test the horns if you ever need to. Just run a ground leg to the metal bracket from the battery and your hot wire to the single pin. Should go beep beep, albeit at a higher or lower pitch since it’s just one.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Check to see that the electrical connector ( long skinny black connector ) on the bottom of the column is completely plugged in.
Something like this :
My brake lights would not work, but everything else would, because this had somehow worked it's way loose when I 1st had the truck.
Troyesco
Bay Area ca
Troy
Ok I’ll check it out this weekend
Troyesco
Bay Area ca
Troy
Swapped out turn signal switch still no turn signals. But I also noticed the light don’t light up on dash when hazard lights flash.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Did they flash before with the hazards?
Do the turn signals flash outside the truck, but not on the dash, or not at all ?
Not sure what year - I will guess 78 - the connector size on the turn signal switch changed.
Wondering if you have the correct switch.
And, can you try plugging the old switch in to the harness - doesn't have to be in the column- to see if maybe it was just a bad connection?
Troyesco
Bay Area ca
Troy
It’s a 73 blazer Lights on dash wouldn’t flash at all but turn signals worked on outside and flashers also. Now only flashers work on outside no turn signals either side. I thought might be turn signal switch but put in a new one and still nothing. I’m gonna be swapping out the dash for a Dakota Digital next week I will see if I can find the problem once the dash is out.
350 w/203
Tilt or no tilt?
Cruise or not?
350 w/203
Do the wires on the 2 meeting connectors match?
Are there any extra or missing in either connector?
Troyesco
Bay Area ca
Troy
Haven’t been able to pull dash out yet will be sometime next week.
350 w/203
See if you can put this into a word document and zoom in.
Doug Hampton
