Hood braces
74 Shortbed
Ok, here they are paint them up and they're good to go, they're yours for the ride, let me know..
highdesertrange
kalifornia
mike
k30
the hood is supposed to bend there. bracing it so it doesn't bend is bypassing a safety feature. if you keep your hinges lubed your hood won't bend. also if you push in as you pull down it won't bend. adding parts so you can bypass maintenance is not good. highdesertranger
Doug Hampton
