I called Norm and asked if I can add smaller injectors to the Sniper and he said NO.
He then said, he can mod the injectors so duty cycle is perfect for the build, ^^^^^^^^ before the Holley ships. He engineers the entire system... reprograms everything to match them custom and ships it. In fact he said the program will most like run as shipped the first time it's installed without having to learn anything.
His build get Dyno'd on his Dyno...
Keep in mind, if you read this and say to yourself, "Thanks Welder, I'll just install custom injectors on my NEW Holley Sniper"... you immediately void the warranty and Holley will block your calls for being too smart for your own good... Norm has permission from Holley to do this, YOU do NOT...
He told me he re-maps the entire computer algorithm, so when you program, the injector size changes are now part of the entire program.
How many guys think about this before they try to add an 800HP TBI to their small block 350HP build?
Then frantically try to down tune the injector duty cycle to nearly zero to keep it running?
Let the engineers do the engineering...
affordable-fuel-injection.com
We discussed the Heritage Sniper which looks like a double pumper, custom built to your specs. It comes with huge injectors... capable of giant HP... your small block will most likely never run right on them and you are not allowed to swap them out, without a new reprogram of the entire system logic.
Do yourself a favor and check it out...
The price he quoted me was very reasonable, lil more than buying from a retailer would cost, and he becomes your tech support Engineer, not Holley... No long hold with Holley,,, ever...
All the issues these other guys have stated is why the error ratio and the bad parts selection issues concern me. Over injected... bad duty cycle... No clue...
I would not cut a divorced manifold unless it was proven on a dyno first...
I'm not able to tell you the system he built me is awesome... My budget precludes me buying his basic systm at this point in my build... He did answer the phone when I called him...
This seems to be the main complaint when buying without using an engineering company, from Holley forums.
If you expect to bolt on a non custom Holley Sniper the way it ships, I would call Holley and get the exact lift and duration for the cam and engine specs they designed it on. Then copy it exactly.
Your engine may not even come close...
Good Luck!
