73c20jim
- Jun 11, 2018
- Tombstone, AZ
- Jim
- C20 2WD Custom Deluxe. C10 2WD Base Model
- 350 CID 195/260 HP Goodwrench crate, 400 CID 2bbl
THE OBJECTIVE: BEST FUEL ECONOMY AT THESE ALTITUDES.
THE TRUCK:
1973 C20 Regular Cab, 8200 GVW, PS, AC, TH350,
195 net/260 gross 350 CID GM Goodrich crate motor, stock exhaust manifolds, true dual exhaust, HEI dizzy
Edelbrock 1405 600 CFM manual choke, square-bore carburetor, sitting on adapter plate to stock spread-bore manifold
THE ENVIRONMENT:
Home base: 4900 ft. 75% of driving
Lowest: 3500 ft. 20% of driving
Highest: 5600 ft. 5% of driving
I would appreciate any input on carb setup, timing, vacuum advance to achieve objective at these high altitudes.
Thanks in advance.
THE TRUCK:
THE ENVIRONMENT:
Thanks in advance.
