1low4x4
- Feb 14, 2011
- Texas
- Nick
- K10
Guys I'm getting parts together for the 65's 350...its a 350 from an 88 suburban.
So far
I'm having it bored .030
New flat top pistons and rings
new oil pump
new cam, rod and main bearings
roller tip rockers
bought a cam kit for it pictured in the link below-
http://www.summitracing.com/parts/CCA-K12-210-2/
These are the things that are done to my dads engine, and it runs strong, nice lope to it...but
Now I have the intake off my 350 and see that its roller cam capable.
Should I go with a roller cam? Less friction, more hp right? I dont mind sending that cam kit back and ordering another-or the higher price. I want to build it right the first time.
If I did this, what heads should I run, Vortec? It has the tbi heads on it now with the bolt thru the middle of the valve cover to hold them on...does it matter what CC and all that?
Could someone give me some direction and maybe find me a good rollercam kit on summit or jegs somewhere and possibly name the heads I need to get the most performance out of it? I dont want to go so radical that it needs a stall.
Also...dont cre about mileage,dont care about what fuel grade I'll have to buy...the trans will be a 700r4...Thanks for any help!
So far
new oil pump
roller tip rockers
