help replacing tie rod boots
jwmoses31
San Antonio TX
Justin
c1500
my passenger side tie rod i can widglle freely back and forth twisting motion but my drivers side is fine i was told the boots need to be replaced how i=do i do this i have a 1982 gmc rear wheel drive and i have a tourque wrench to use on the bolts
AJII
Jackson, TN
AJ
The tie rod end itself needs to be replaced if it's loose. Not just the boot. Boot merely holds in grease.
jwmoses31
San Antonio TX
Justin
c1500
So i buy a whole new tie rod assembly and boots? and replace the whole thing
jwmoses31
San Antonio TX
Justin
c1500
whole new tie rod and assembly with dust boots aqauried today so i shall start to work on it soon
8T6K5
AZ
L98 350 TPI
As in for both sides right?
I dont recommend just doing one side.
Make sure you count the number of turns taking the old ones off!!
jwmoses31
San Antonio TX
Justin
c1500
i did both and number of turns were counted for every bolt take off and wow its much better no jeking wheel tighter steering its like a new struck
Cooltx
