Coal creek Chris
- Oct 5, 2019
- Colorado
- Chris
- V3500
- 7.4L
How important is it for coolant from the heater hose to pass through the TBI on an 89 V3500 with 7.4L engine? While doing another project, I noticed that the heater hose connection at the back of the TBI is loose and looks like the connector plastic is partially broken. This is a heater hose with a metal end that snaps into a fitting on the TBI. The other end of the heater hose is rubber and attaches to heater core with a clamp. The fitting is the bigger one in the center of the photo, the other two are fuel. Looks like one of those projects that could turn into a mess if I try to replace the fitting that threads into the TBI, so I was wondering about bypassing it to the small coolant hose on the front of the TBI. But only if it won't cause other big problems or if it is essential that the TBI has coolant flow through it . Any thoughts and suggestions would be great. I live in a place with winter if that matters for this question. Thanks.
