Head gasket options
RangRayy
Kansas City, Missouri
ryan
r10
Just like the title says^^^ I need ideas on what brand, thickness and tips on selecting the right head gasket.
In the middle of my intake swap I figured what the hell let's pull a head and see what kind of shape the cylinders are in. Long story short I am pleased with how they look, a little cleaning and it should be fine.
The engine is out of the truck and on the stand in my garage. After work I plan on pulling the other head and hopefully having the heads pressure tested. If all checks out ok I may let them clean the surface but no resurfacing. What type of gasket is suggested? I have tbi head 14102193
Edited to add casting of head if it makes a difference.
phinix
Worcester, MA
Bryan
5.7L 350
Is it stock or modified cause if its stock you should be able to get the OEM head bit if its modified your gonna have to take a couple of measurements to figure out what you need
RangRayy
ryan
r10
It is stock as far as I know. Upon cleaning the Pistons last night I noticed a majority of them had a 3 stamped but not the 030 that means bored .30 over. Whatever the regular 3 means I haven't a clue.
I measured the bores with a set of calipers and every one measured out to be 3.995 almost a 4" bore. Now I know to get a more acurate reading I should've used a dial bore gauge but I didn't have one laying around.
I found this on several other sites OEM #10105117. Meant for a 4" bore at compressed thickness .28. That's what gets me lost what thickness to use.
firebane
Calgary, AB
Curtis
Not sure on the specifics of your block but on my engine in my 74 I used Felpro 1094 gaskets. They are 0.015 thick.
Don't forget a 350 block is around 3.9-4.0 bore.
What you should do is find out how far up the cylinder the piston comes and choose your gasket that way.
The ideal quench for a sbc 350 is around 0.040 to 0.045 and Chevy was notorious for putting thicker than needed gaskets for "emissions" and safety reasons. My pistons were 0.030 down the hole so I went a little on the safe side and went with a 0.045 squish hence the 0.015 gasket.
85c10owner
Sacramento, CA
Anthony
Call a GM dealer and have them look up a replacement set of head gaskets and ask what the thickness is. GM use to use the shim .015 thick gaskets but with the TBI stuff I think they went to a little thicker gasket. The bore of your engine should be 4.0 if standard. Head gaskets come in a variety of gasket bore sizes from 4.0 all the way up to 4.160 or more. Safe bet is getting the GM gaskets from the dealer unless someone can give you a actual spec. And make sure they are compatable with iron heads. some with only work with aluminum.
Doug Hampton
