Hardware/fixing specs for 75 front end? Replacing clip with original and not sure what I need for the job.
Alexc
NZ
Alex
5.7l
Looking to replace my clip (has a late 80s currently) and will need hardware but the kits are expensive! Hoping to piece together something myself. I have 75 inners/fenders/hood/bumper/core/trim/lights ready to go
What can I reuse from the existing clip? It's complete and all bolted on currently. Think it's mostly 87 with a 90 grill (quad headlights). What are some things I'll need that I'm not thinking of?
Bennyt
Surprise
Ben
You may need to do frame repair to mount the 70's bumper. I believe that they had to be cut for the 80's stuff to fit correctly.
If you plan on lowering the truck, you may want to modify the '80's inner fenders as they have more clearance.
I purchased Dorman hardware in bulk on Rockauto for substantially less than I could find anywhere else. I think 10-20 cents compared to 50 cents to a dollar from restoration places per bolt/ clip. I think there is two different sizes for most.
Catbox
Peter
C20 Silverado Camper Special
Well hot dayum.
I did not even know they had that section on Rock Auto.
I will be using that to replace the hardware on my Bel Air as it has the bare minimum holding the front clip together....
gtewolf79
