Glove box issue
wapnw
arizona
wyatt
How do I separate the metal cover from the glovebox? I have already removed the glove box lock but having a lot of trouble separating the two main pieces
Juggernaut
Illinois
Greg
You're on the right track. You already got the hard part, it took me a while to figure out the latch. Looks like you're just a little crooked, it may be pinched. Mine slid right out, although it was tight
Scott91370
Burleson, Tx
Scott
Sierra1500
Keep working it, you're heading in the correct direction. The plastic or metal may be a little messed up making it hard to get them apaer - but you're doing ti right.
Ken B
indiana
ken
tagging onto this thread....same project. but how do you separate the latch/lock so you can then replace the plastic "tub.
my latch is a little loose in the metal glove box door but I can not see how to separate the latch......any help would be appreciated
Juggernaut
Illinois
Greg
Use a small screwdriver to push in on this small tab. Cylinder then pulls straight out
Ken B
indiana
ken
Thanks. Will try that!
waterpirate
delaware
v10
5.7 tbi
Good Luck! Mine was so corroded I bought a new one and cut the old one in half with a cut off wheel.
YMMV
2manysquares2care
