The only poster that is correct is SirRobyNO. On the 1987, each tank sending unit has (3) hose connections: pressure, return and tank vent. If you have dual tanks, the left and right tank vent hoses are
next to the fuel tank selector valve on the R/H side on the inside frame rail. The lines "Tee" together and
connect to a steel hard line that runs down the inside of the frame, turns left, then runs along the front crossmember to the charcoal cannister. Here is what happened to me (2) months ago. I removed the bed on my '87 R30 to replace the pumps and sending units on both tanks. Every thing went good. I drove on the left tank for a few days. When I got down to 1/4 tank I switched to the R/H tank. I drove on the right tank for a couple of days then stopped at the gas station to fill-up. When I removed the cap on the right tank a lot of pressure released. At first I thought the cap was defective but I remembered that '87s don't have vented caps. Well crap!
Now I have to find out WTF is wrong. Starting at the charcoal cannister I removed the tank vent line. I applied pressure to check for a blockage. Yep, it was blocked. Next, I removed the 1/4" rubber hose from the steel hard line by the fuel selector valve and checked for blockage back to the cannister-ok-no blockage. Next, I separated the L/H and R/H vent lines at the "Tee" fitting by the selector valve. I checked for blockage from the hose at the "Tee" to the tank sending unit-blocked!!!!! Well, that's not what I wanted to find, but that's my luck! Well, I was not about to remove the bed again and dropping the tank is very difficult when you have a 20 gal. tank because it's longer and that makes reaching the hose connections at the sending unit difficult. (it's easier on 16 gal. tanks because they are shorter). When I had the bed off I wanted to change the (3) hoses that go from the sending unit to the selector valve(they were 34 yrs. old). They are no longer available, so I replaced them with HiQuality hoses and left enough slack to be able to lower the tank down enough to access the connections. After I got the tank down I removed the new sending unit and put it on the bench to check the vent valve. It is mounted to the underside of the mounting flange of the sender. Blocked!!! It is plastic and pressed into the steel line on the sender. BTW-the sender is made in China-imagine that!! I removed the vent valve from my original GM-made in
USA-sender and installed it on the new sender. Installed sender back on tank-installed tank-vents good!!!
I know this a long and boring post but thanks for letting me relate my experience to the forum.
