Gas in Oil!?
Barrett-FL
Central Florida
Barrett
I have two issues. One causing the other with my 86 C-10 which has a 350 with 4-barrel Ellerbrock carb and intake.
It's a project and doesn't get driven yet. After sitting a few days the gas seems to drain back from the fuel line, it takes a lot of pumping the gas peddle to get fuel to the glass fuel filter and to the carb to get it started. Once the fuel filter is full it will start right up daily, but if I let it sit a couple days it's hard to start due to the lack of fuel in the line.
The time I started it to move it it began spewing oil mixed with gasoline. I can't see where it was coming from but it covered the engine and engine bay with the fan blowing it. The oil dipstick was over filled due to the gasoline and one could smell the gas on the dipstick.
I drained the oil and replaced the filter and ready to refill the oil but I'm somewhat afraid to do so and to start it without knowing what happened and how to stop or avoid it from happening again. I would hate for it to do it again and repeat the process.
Has anyone had issues with gasoline getting into the oil and what I can do to solve it?
I appreciate any sound advice.
Thanks!
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I experienced this twice - once on a large GM 4 door car and once on a Jeep with a 2.5L GM engine. In both cases, the diaphram on the mechanical fuel pump had ruptured, so as the engine was turning the pump was cheerfully filling the crankcase with fuel. Not fun, definately check it before trying to run the engine again because otherwise you'll have just wasted/contaminated another 5qts of oil.
Barrett-FL
Central Florida
Barrett
Thank you for your responses.
I suppose the best thing to do is replace the fuel pump and give it a try.
One thing I’m concerned about is where did the oil leak out from and will the oil leak out again when running.
Also, will replacing the pump stop the fuel from leaking back from the fuel filter?
Thanks again!
fast 99
Spokane, Washington
Fuel pumps have check valves. Replace the pump then if problem persists move on to other areas.
Suspect ethanol fuel did some of the damage.
oldsquarebodyboy
