kingscc
- Jul 24, 2023
- St Paul, MN
- Jason
- C10
- 5.3 LS
I have an 84 C10 with a weird lighting issue. All of the exterior lights work.. Headlights High and low beam, Tail Lights, Marker Lights, Parking lights all work. Both rear blinkers work with both the hazard flashers and the turn signal switch. Front blinkers do not work at all. Have tried several bulbs, checked the wiring all the way to the bulkhead harness and have continuity. Good grounds on both sides. No voltage on the turn signal wires at the cluster harness either. I do not know where the turn signal wires split to the front and rear but maybe that is where the issue is?? I am testing Light Blue and Dark Blue wires. Anyone know where they split or if the front has a separate fuse or fusible link? I don't really know where to go from here. Any help would be greatly apreciated.
