1986 GMC 1500 Sierra Classic 4x4 SWB w/305” on a 700R4
I’m doing the front brakes.
what is the size of the specialty socket for removing the first hub nut?
and what makes it “special?”
I''m assuming you are changing rotors?
You
It's got 4 prongs that stick out and engage in the 4 lock nuts so it's not a size so much, you just have to find some place that knows what it is and sells it. Amazon has it if you have time to wait - OEM tools part # 25072. I just checked stock at one of my local autozones and it says in stock so you might check there first to see if they have a loaner (also oreillys or whatever) and/or if not then have one in stock. Autozone is usually pretty good about just opening a shelf tool and making it a loaner if they don't have one to loan out already.
Sorry for the huge photo but I didnt want to do any work on reducing it but you can see what makes it work.
Just some advice before you go Gonzo. Your also going to need a pair of snap ring pliers that open when you close the handles, and I would recommend a couple of strong angle headed picks to get the circlip parts that hold the hub innards out. If you still have those auto locking hubs it might be time to upgrade those as well. There is a premium set of Mile marker hubs at Advance for like 60 bucks. Buy yourself about a case of brake cleaner and you might want to go ahead and prepare to buy bearings and seals and a tub if high heat grease as well since you are in there and if it has not been done in a long time or ever then you are probably going to get it apart and find out it you have hidden damage and it needs it. The previous owner of my axles let the seals go bad on the hubs and it ruined the expensive cast metal set of Warn hubs they had installed
Here is a video I found on youtube to help along. I have not finished watching it to see if there is any misinformation but so far he has a good start, lol...
