gotyourgoat
- Mar 27, 2014
- NRV Virginia
- gotyourgoat
- c10
- smokin' 305
Would work how it's supposed to from the factory. The other tank which you said was screwed shut likely has some sort of issue and/or it could have an issue with the tank switch. Did the seller have any info on this truck?Yeah I think tha they are the original fuel lines. Thanks for the link. I'll have to look into that before long. Not sure how a return hose would work with two tanks if I eventually ge tthe second tank working too
I get trying to do as little as possible to get going but doing it twice isn't any better on your wallet or your time. The return line helps with the vapor lock @SirRobyn0 was talking about. Aids in keeping a usable pressure while cooling of said fuel.
Honestly depending on the use of the truck and what it actually needs it might be worth a shot getting the proper pump and running new rubber lines back to the working tank. Attached to the frame of course. The old lines are in question of being physically there and their condition is a crap shoot. If the lines are indeed there and you hook them up causing 40 years of diesel and dirt to come out wrecking the new pump and the carb. That is no good and this thread will take a terrible turn.
