- Feb 5, 2014
- Kentucky
- David
- K10/LM7 5.3/4L60e/np208/3.73/32"
- 10 yrs Air Force
I've got 2 ft floor joist in the basement that are about 12 1/2" apart. If I make a square frame say 3'x3' resting on 4 joist, with a hook in the middle, do you think it would be plenty to put a hoist on it to lift an engine/tranny with out hurting the house?
I don't have drywall up so that isn't an issue. I could also put some iron, from each corner, to the center and have the hoist above the ceiling line in case we put drywall up later.
Above the joist is the living area with an unfinished basement. The house is roughly 50'x25' with a pretty steep pitch.
Thanks In Advance
Edit: the house was built in 2007, and has cinderblock that the joists rest on.
Thanks In Advance
