Cragmor
- Oct 5, 2020
- Iowa
- Jerry
- C10
I pulled the ID and casting number from my block. I have a 76 C10, but the engine appears to be a 75 350 pulled from a C20, based off of the block ID.
V1007TXR 1975 350 fwrd cab c-20 to 3500 165hp 4bbl l ls9
Casting number appears to be missing a digit. I have 39700_0. Looking up what I know, it appears that the digit should be a 1. That fits the year and CID. What I was hoping to learn was if this was a 2 or 4 bolt main. So, hoping some guru hear can take both bits of info and determine if that since the engine came from a heavier duty truck, would it be more likely to have a 4 bolt. Or, during the mid 70's was it just chaos, lol.
Just got the truck so still sorting out what I want to do. Have not had a chance to even consider pulling the oil pan yet. I will if need be.
